Old 12-04-2010, 11:38 AM   #7
I did this and I tried to use a Mikuni pump but I had to use the stock OMP because my braided lines wouldn't work with the Mikuni the way I have the lines routed, which I believe is in the stock way too haha. In the last pic where the lines are running right next to each other and attach to the OMP, on the Mikuni there isn't as much room for them to fit right next to each other like that, but I believe if I rerouted the lines it might work.
I got a tank from US Plastics, drilled a hole in the bottom rear of the tank and used ss braided line. I just mounted it where the battery would normally be. It's a little farther away than I'd like it to be but it's on the cooler side of the engine bay. I wanted to use a plastic tank so I could easily check the oil level. I used SS braided line because I figured it would hold up better than rubber hose or the transparent plastic line, and because I wanted fittings for the ends instead of just clamping the hose down over a nipple.
