#1 | ||
I knew a guy who put down 202 WHp on a dynojet using an RE intake. I think that GtoRX7's FC has an NA 13BRE in it at 230 WHp. I would expect that 215-225 WHp is reasonable to expect NA. Quote:
I have heard of converting a 6-port to a 4-port by removing all the material between the ports, the sleeve, etc. I think this port would be way too big to make power at any reasonable speed or with the intake runner size that even an RE manifold has. I am thinking that a custom intake (for the 6-port) with short runners or ITBs is your friend.
for ITB's, would 4 38mm throttle be big enough?
for a SP or even a half-bridge?
ULTIMATE N/A |
#3 | |
I saw a couple builds and they both were using 3 48mm TBs, one for the two primary ports and one for each secondary port. 3 44s would probably be sufficient. This flows about the same as 4 38s, but the flow into the secondary ports is a lot higher than the flow into the primaries and needs the throttle sizing to be correct.
