| Interior, Stereo, Body kits, etc... Place where you could talk about car care, body kits, painting your car, Carbon Fiber, Thumping Stereo, etc.. |
#14 | ||
Rep Power: 10 ![]() |
Always wear gloves and clothes you don't care about never sand without a respirator (those little surgical masks don't cut it) when you're done... take a COLD shower, as cold as you can stand and don't scrub... just rinse. When forming shapes, the first one or two layers, use mat, not woven. after the shape is there, switch to woven or bi-axial NEVER let it fully harden if you're laminating.... wait until the epoxy starts to kick... if you can run you're fingers over it and drag it a little, but still leave a fingerprint, that's when you apply the next layer. This gives you a chemical bond, not just a mechanical bond. If you let it harden and then apply the next layer, you're left with a mechanical bond and if it's ever going to delaminate, this is where it will happen. When you move onto the next layer, wet the first layer by appling a coat of resin. If the pieces are small enough that you can wet them out first, do so, I usually have a scrap piece of wood that I'll roll some resin on, put the PRE-cut pice of mat or woven on, roll that into the epoxy, put it on the piece that's getting laminated, then apply a little more resin making sure all the air bubbles are out. Don't go with too many layers, flexibility is you're friend. Quote:
My thought, probably didn't explain it well enough, was to use the sheet metal as a backing plate and sandwich the plastic piece between the backing plate and the tweeter..... but as you pointed out, that still leaves the crack to be dealt with.
