Old 10-06-2010, 05:58 PM   #1
I really wish there was an engine simulator out there that could do the flame propagation calculations and show you the issues with timing. I would write it up, but I am
  1. Not getting paid enough to write something like that
  2. I don't want to be the source of legal action when what I program isn't how it works in real life because some one didn't do something with their engine
  3. I am not familiar enough with GUI programing outside of matlab which can not run stand alone applications without an expensive add on deal
  4. And I'm only partially familiar with the concept of numerically computing the combustion process on a rotary
As to the OP I say it's an issue with the timing. If you're running .7 Lambda you should be making peak power with the proper timing, however it may also be due to other various reasons and to pin point it to a single cause I would have to see the actual numbers from the datalog.
For all I know a squirrel could have been sucked in by that massive turbo, made it through the impeller unscathed, and decided to munch on your apex seals while it went around the combustion process. Only to lose one of its teeth and that single tooth cracked the side housing.
As a word of advice I stopped listening to most people on the other forum after receiving the advice that I should rotate the engine slowly by hand until a bolt I had accidentally dropped down my intake manifold popped out the exhaust./true story
Old 10-06-2010, 08:29 PM   #2
FC3S Murray
frustrated!
FC3S Murray's Avatar
LOL I actually know of thread that I believe that same member posted that exact same advice.
I tell the OP to go V8
Same pig, new soul
Old 10-06-2010, 09:58 PM   #3
FC Zach
FC Zach's Avatar
"For all I know a squirrel could have been sucked in by that massive turbo, made it through the impeller unscathed, and decided to munch on your apex seals while it went around the combustion process."
LMAO! Creative writing at its best!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-07-2010, 08:44 AM   #4
How much you want to bet it was the same thread?
http://www.rx7club.com/showthread.php?t=734707
hahaha, looks like some one edited it but you notice a person mentioned not to do it to something that was 'apparently' never stated in the thread...
Censorship at it's finest
