Old 09-29-2010, 10:29 PM   #3
I spent ALOT of time filing down the inside of the tube to more closely match the arc of the threaded tub. Almost 3/16" of an inch gap is just too much so it had to be filed down. Thinking ahead before you cut too is also key. I almost ruined that piece by getting a little excited.
Everything aligned and clamped down on the bench. Again, sooooo nice to have a good bench. Level, true and you can weld right on it.
One great bead, one shitty bead.
After a lil more welding and some grinding - DONE! Time to instal.
Installed on the car. So nice and easy to get on. Swap the brakets and instal one hiem joint to the bracket snugly. Put the other in the rough spot where it needs to be and rotate the entire brace until it falls into line. Tighten both bolts down and give the bar a turn or too more to load it up and jam down the lock nuts. Pre-load is a good thing sometimes.
