Old 09-29-2010, 10:29 PM   #2
Drill a 3/4" hole and viola. What I generally do when I need to get throught two pieces of metal like that is drill a pilot hole, 1/8" or so through both and check for square and true, then go for the big 3/4" hole. Easy to adjust an 1/8", difficult to adjust a 3/4"
Starting with the 1x2x1/8" 6061 tubing and the opposite thread section of pipe. In reality all I really needed to do was order a length of threaded pipe the correct length (about 21") and been done with it. But then it wouldn't be original. Plus I'm building a front & rear strut bar out of the same material so now it all matches
A few measurements later and out came the jig saw. You'll see why in a minute.
I spent ALOT of time filing down the inside of the tube to more closely match the arc of the threaded tub. Almost 3/16" of an inch gap is just too much so it had to be filed down. Thinking ahead before you cut too is also key. I almost ruined that piece by getting a little excited.
