Old 09-09-2010, 10:32 PM   #4
NoDOHC
NoDOHC's Avatar
Good call there TitaniumTT, I meant to reference the post that I had read, but it must have been elsewhere or has been deleted, as I couldn't find it. I meant to replace the existing relays with the Bosch style and leave the wiring intact (there is a writeup somewhere that shows how to do this).
Then the only wiring that may need to be replaced is merely from the fuse block by the shock tower to the new relay (not too bad).
An interesting question would be why the stock headlamps are inadequate? Do you intend to rally race at night?
edit: I was wrong about the switch, I guess it does just drive the relay coil, so why does it fail?
