Old 08-22-2010, 02:24 PM   #1
WTB: Powersteering pump (with one pressure line) for s5
I need a power steering pump for an s5 car. (I don't know if an s4 pump will work.) I believe it is the Engine Speed sensitive power steering pump, and only has one pressure line from the pump to the rack. The extra location for the other line is not drilled, so only this certain pump can be used.
Car is a '90 vert. I will need the whole assembly, including brackets, pullies, and lines (1 pressure, 1 return). If you have the mounting nuts that would be a plus.
Thanks! Let me know what you have!
