Old 07-27-2010, 02:53 AM   #5
a 250 idle is pretty indicative of one rotor operation. Check the usual culprits, injectors, ignition. The hit the FSM and follow the procedure for adjusting the idle. The n/a does not have the adjustment screw on the BAC, those are the turbo cars.
The BAC is to maintain idle. You want, at least the way I set them inthe aftermkt ecu world, a solid idle without using the BAC valve, use thee BAC valve to maintain it.
