#10 |
Rep Power: 10 ![]() |
There is alot of accurate information here regarding the inaccuracy of the stock gauges. Fact of the matter is that the stock tach, as Ted pointed out is eay off. I was seeing ~4-500 rpm difference compared to the S-AFC and the Autometer tach that I was using to test the accuracy as well much like the sentwo.
Your speedo is also off. I've said it before that I've never seen an accurate stock speedo. Don't know why companies do this but I've seen stock speedo's off by as much as 10%. Hell, I went from a 225/75/15 tire (28.28") to a 31", a difference of ~10% and my speedo up to about 70 FINALLY became accurate. After 70 the speedo actually shows slightly slower than what the GPS/police radar will show. Something to be aware of. Other points of concern are how the speedo works, there is a spring involved, springs do fatigue, and the fact that tires are always slipping or rotating at different RPM's will cause reading's to jump around as well. The most accurate way to get readings is not going to be from an analog gauge, but rather from high quality electronic sensors, really sheilded wiring, and digital displays. Things the RX8 has. Can anyone comment on the accuracy of the the RX8 gauges?
