Old 07-17-2010, 09:17 AM   #5
B/Y or B/W are switched 12V that are constant through cranking which is important. you're in the unfortuneate situation where you're still running all stock ign/inj components that rely on those wires so I would use them to power a relay, and that's all.
I BELIEVE that the L/W wire (audio amplifier?) is hot through cranking as well. I believe it's called ign 1 in that little box that breaks out the key positions. That's the one I would use UNLESS you have the factory amps still up and running.
Again, this is all through memory so I could be wrong.
