Old 06-29-2010, 02:09 AM   #5
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
Originally Posted by Prometheus View Post
what modification is needed in order to be able to mount the 190 amp GM unit?
+1
Originally Posted by Trout2 View Post
The GM/Delco alternators come with several different moutning points. A Delco CS-144 alternator from a late 90's model Camaro will fit on an FD with modification to the adjustor bracket. These can be built to put out up to 200 A.
Sport Tuner, see the vendor section here, can rebuild the stock alternator to put out 140 A or so.
Jack
ive been searching for the delco cs-144 and these two come up...
321-1114 and 334-2435...... do you know which is the correct one?
howd u make your bracket? does the fd pulley fit right in? alt connector fits in the same as well?
Bubble Tech
www.BubbleTech.us
muibubbles is offline   Reply With Quote
