Old 06-27-2010, 08:59 PM   #1
Bass
Bass's Avatar
Bass is on a distinguished road
weber set-up
Hi there! This is my first post on here. I've got a an issue that I'm hoping somebody can point me in the right direction.
I've got a street ported 12A that's well broken in with about 8K in the rebuild. What I'm looking for is a complete set of numbers (including air jets, fuel jets, pump jet, emulsion tube etc...) for what I should start with as a baseline for the weber. From there, I can begin to tweak the carb as needed as I have access to all the jets etc that I would need.
Hope you can help.
'83GS: RB header, RB presilencer, magnaflow muffler,e-fan, solid motor mounts, RB springs and sway bar,Tokico shocks, poly bushings, stainless steel lines, 12lb flywheel, weber 48 IDA, Carter fuel pump, Holley FPR, RPM streetported 12A, 15 inch rims
Bass is offline   Reply With Quote
