Rep Power: 22 ![]() |
Yes, straight from Corbeau--> http://www.corbeau.com/service/seat_brackets/
They had the Corbeau symbol on them, as well as the part number and 'FC3S 86-91' Even on Corbeau's site they are $89, some places might have them cheaper.
IT'S ALIVE!
Rep Power: 17 ![]() |
Ugh, Wedge's are up to $110/ea - screw that. I'm going to be picking up some 3/4" square tubing and 1/8" flat stock aluminum tonight and try to tackle the driver's side tomorrow.
IT'S ALIVE!
Well, got the bracket components all fabbed up for the driver's side. I just need to get some longer bolts to hold everything together and hopefully it'll all fit in.
On a related note it's going to be a damn tight fit with the Torino II's. Maybe everything will line up better when it's installed but the initial test fit was discouraging. |
IT'S ALIVE!
End results attached below. Pictures show the 3/4" square tubing I initially used but that resulting in a seating position that was too high. I ended up using some 1/4"x1" flat stock (needed to be thickn enough to clear some features on the stock brackets) and everything is good. The end result is essentially the same (only seating height changed).
Is that aluminum?
If so, for safety sake, please change it to mild steel. Aluminum work hardens very quickly and can fail with very little warning. -Ted |
#6 | |
IT'S ALIVE!
I will be removing these again in a few weeks to see how they're holding up. If I see signs of distress I will likely go buy some mild steel bits and take them to a machine shop to be put together (i.e. welded) in a manner similar to the current configuration. |
IT'S ALIVE!
Ugh, so even after swapping out the 3/4" square tubing for 1/4" flat stock the driver's seat is still too high. With my helmet on my head hits the roof and I'm not a very tall person (5'-10" at best). Even though I dislike them I am seriously considering the Wedge brackets and Sparco sliders, but I don't know if that setup would be any lower.
Does anyone know if side-mounted seats are any higher/lower than the reclineables? Lately I've been considering selling the Torino II's and picking up something FIA approved like the Evo. Anyone have the Evo's or something similar in an FC? Last edited by infernosg; 07-23-2010 at 08:37 PM. |
