Old 08-09-2010, 01:43 PM   #1
Originally Posted by Nismo View Post
You just resolder the 10pins or whatever for the connector, and it will fix it!
Not necessarily true. For instance my clock situation was caused by the ribbon cables actually breaking out of their solder joints. They would make contact but any jolt or bump caused them to lose contact and reset the clock.
Ever since I fixed it and re-soldered everything it has kept accurate and bright time. Only dimming when I turn on the lights (as they should).
Old 08-08-2010, 12:00 PM   #2
NYsNumba1Man
NYsNumba1Man's Avatar
NYsNumba1Man is on a distinguished road
how good do you have to be at sodering though?
I've sodered a few things before, but i've read about people trying to resoder their wiper switches and messing it up then having to buy a completely new switch. I pmed pele and some other guy in the nyc area on the 7club before but i didn't feel like spending 50-75 on a switch
Originally Posted by Turbo II Rotor View Post
What if they bolted rotary engines to rotary engines to rotary engines to rotary engines to rotary engines to rotary to rotary engines to a rotary engine?
NYsNumba1Man is offline   Reply With Quote
Old 08-09-2010, 01:45 PM   #3
I would offer my help, but I've never soldered the switch together (though I've done plenty of soldering).
Old 08-09-2010, 09:01 PM   #4
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
It's not too hard.. just follow the directions in the writeup. I did mine with limited experience. I found that the trick to de-soldering is A: a solder wick, not a solder sucker (worked WAY better for me) B: Apply a little flux to your wick C: Pinch the end of the wick down onto the solder with the tip of your soldering iron... wait a few seconds and PRESTO! You'll get some of the pins in a single attempt this way.
1988 GXL
Old 08-08-2010, 01:47 PM   #5
Nismo
400WHP or bust
Nismo's Avatar
It's more or less being good at removing old solder, if you can get it off quick you are good to go, if you heat the hell out of the board and the contact ring lifts you are screwed, and need a new one. Parts are 30 bucks, and 30-50 is resonable to pay someone for time, and return shipping.
Old 08-10-2010, 01:53 AM   #6
NYsNumba1Man
link to this write up?
http://www.rotorwiki.com/index.php/Wiper_Switch_Fix
I'm assuming thats it, but my browser won't load it for some reason.
Old 08-18-2010, 12:08 PM   #7
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
Site appears to be down. I can't even open the home page. Hope it is temporary.
RotaryDiagnostics is offline   Reply With Quote
Old 09-11-2010, 10:04 PM   #8
WildBillMassey
Wild Bill Certified
WildBillMassey's Avatar
WildBillMassey is on a distinguished road
I have switches.....
http://rotarycarclub.com/rotary_foru...ad.php?t=12150
WildBillMassey is offline   Reply With Quote
Old 08-18-2010, 10:04 AM   #9
Sharingan 19
Sharingan 19 is on a distinguished road
My buddy (Landon303...on the other forum) is rebuilding wiper switches for 30 shipped.
Sharingan 19 is offline   Reply With Quote
