Old 05-10-2010, 02:50 PM   #2
Originally Posted by hecmanortiz View Post
I'm going to look at an 85 with a 12A that has been sitting for some time. The owner said that it was his daily driver for several years before work kept him away from home. He said that the last time it was started was about 2 years ago and before that it didn't idle. I am assuming that the engine is still good but am worried about the effects of it sitting for so long. I assume that it will have to be towed to the house where a fresh battery, old gas drain and carb cleaniing are in order. Is there anything that needs to be done to the engine before cranking it? I'm thinking of removing the plugs and try to turn the engine to ensure it moves freely then treat it like a flooded 12A with some oil to let the seals do their thing.
Thanks,
Hector
Honestly if it's sat for 2 years without running, I'd look at the combustion chambers, ensure the seals are still good, flush all fluids. If you have a bore scope look in the engine and see if there's any rust or flaking Chrome. If there is, don't even bother starting the engine, just pull it and prep it for a re-build.
furthermore look for rodent damage. Wires eaten, nests made, etc.
