Old 04-02-2010, 06:36 AM   #8
infernosg
IT'S ALIVE!
infernosg's Avatar
If you're nice to the guys @ discount tire direct and phrase it properly, they'll send you a set of hub-centric rings for free. Then you're just looking at a set of off the self spacers.
I really like you're thinking though
LOL, thanks!
I actually already have a set of hub rings and everything works fine sans the slight contact in the front. My concern with the off-the-shelf spacers is their cooperation with my current hub rings. They're only like 10mm in thickness so if the 10mm spacer had a center bore of greater than 73mm (Enkei bore size) then the hub ring would end up inside the spacer and not really do anything. I know eBay sells the spacers that are supposedly hubcentric quoting hub bore as either 59.5mm or 60.1mm. If the former were true I could just put my current rings over the spacer and all would be good. I may end up going that route as, just depends on what the shop comes back with.
Either way, I think I'm actually just going to have them quote a hubcentric 10mm spacer with the stock bore, then I'll just use my current hub rings. If anyone else were interested I feel this would get the best response - I'll see what a bulk price would be next week (probably Wed.).
One last question, I read another post here that in order to install longer wheel studs in the rear the hub has to be removed - is this correct?
