Old 06-17-2012, 12:30 PM   #1
Pettersen
Damn, didn't get started on the bodywork, other stuff came in the way...
Anyway, irons have arrived so i just need to try to port the junk irons and then i should be able to do a good job with the "new" irons
Old 07-06-2012, 11:32 AM   #2
Pettersen
Soo, my plans have changed. Or rather im going back to school after the summer and see if i can't manage to become an engineer. So i need to thigten up the budget. Wich means i will be going with T2 rotors (means i don't have to buy a flywheel and rear counterweight) and i bought a PFC with datalogit from a friend (got it cheap since i have helped him working on his car).
So to sum up the new plans for the engine:
Apexi pfc
S4T2 rotors
Stock flywheel
semi pp and mild streetport.
Modified T2 lim
FD UIM and TB with adapterplate to fit the t2 lim (i have checked with an old gasket and it doesn't seem like a very big project)
Rotaryworks 2*2,25" header
Custom 2,5" exhaust
The only things i need to buy are the banzai adapterkit for the PFC and parts to build the new exhaust, so should be doable to get this done before school starts.
Now i just need to finish my coffee, and go in the garage and try to port my junk irons and then start on the irons i'm actually going to use when i feel i'm ready.
Old 07-21-2012, 12:17 PM   #3
Wide fenders? Awesome!
Old 07-21-2012, 06:01 PM   #4
Pettersen
Well, i will give it a go anyway..
Old 07-22-2012, 11:44 PM   #5
Is that a special kind of light? If so, what is the purpose?
Old 07-23-2012, 01:36 PM   #6
Pettersen
It's a sun tanning lamp, with UV and IR. So it takes shorter for the resin to harden.
Old 07-23-2012, 09:40 PM   #7
Gotcha. I wondered about that. But I also wondered if it was to inspect certain aspects of your work or something lol.
Old 07-29-2012, 10:28 AM   #8
Pettersen
Old 08-05-2012, 01:08 PM   #9
Pettersen
some progress, spaced the widening plate out 20mm from the base plate, and applied some foam and tried to shape it towards the door, not real happy with the result, need to change some things, maby start tapering it inwards earlier.
Old 10-22-2012, 01:13 AM   #10
Pettersen
http://www.ebay.com/itm/280905503770...S:3160&vxp=mtr
Old 10-27-2012, 03:33 PM   #11
Pettersen
Old 10-19-2013, 09:30 AM   #12
RedR1
Brokeback Power!
RedR1's Avatar
RedR1 will become famous soon enough
very nice!! i love seeing updates to build threads!! Sad that the ITB had to be put on hold, but it seems like you're having a lot more fun right now
RedR1 is offline   Reply With Quote
Old 02-05-2014, 12:25 PM   #13
Pettersen
Aerokit Spec D +20mm fenders to replace my dented stock ones. Hoping to get them fitted to the car in my Easter vacation.
Old 04-11-2015, 03:42 PM   #14
Pettersen
Finally made and installed a working itb setup. Should get it dynoed some time this summer.
Some short clips, before and after.
Old 04-12-2015, 07:03 AM   #15
Are those the 42's you were talking about?
They sound really nice!
Aside from the really low RPM stumble on the last vid, the throttle response is damn crisp!
Motorcycle TB's?
I assume you're going to eventually go turbo with this set-up?
