Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > NRS Rotorsports
NRS Rotorsports www.nrsrotorsports.com (Canada) Ceramic apex & corner seals for rotary engine applications
Old 02-21-2010, 12:20 PM   #17
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
RX8 rotor & cut away for 3mm full height seals
A customer of mine in Russia is looking at running 3mm full height ceramic seals in RX8 rotors. Below is a pic of an RX8 rotor cut away showing the meat available in the slot as well as a stock RX8 rotor for comparison. Please note the cut away slot is not standard RX8 depth because they were using apex seals that are in between OEM height (FD) and RX8 height at 3mm width. Their slot in the cut away is 8.80mm or 0.3464", the total meat available is 12.20mm or 0.4803". This leaves approx 0.1339" to the bottom of the casting. The full height slot should be 0.385" deep leaving 0.0953" of meat remaining, almost 100 thou. From the picture the slot would be deepened another 0.0386", less than 1mm.
Hopefully this info will help others to make a solid decision when considering 3mm full height seals in RX8 rotors.
Thanks Dmitry for this excellent info!
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
glassman is offline   Reply With Quote
