Old 01-04-2015, 04:21 PM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Sweet!
Thanks
I've done even more detail work to the COP adaptor/s.... It's fucking sweet ass now, very tight design and 99% optimized now. I'm happy with everything else, many days refining to point where I would class it as almost perfect now.
Sure is better than my last COP set up which I just slapped together
still lasted without issues for years.... must know what I am doing lol.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-04-2015, 10:41 PM   #2
I actually thought your previous setup was awesome too lol. I've wanted to do a COP setup at least since I saw the first setup, but I figured I never would. You've probably covered this before, but other than no "line drop" over the length of plug wires, and no wires that degrade over time, what are the advantages of COP over using wires?
So I assume that after you make a set of these you'll test them on your car in true RR fashion and log different parameters and get all scientific with it? lol
Old 01-04-2015, 10:50 PM   #3
RICE RACING
Don Mega
Advantages
* zero power loss
* RFI immune
* ultimate coil cooling
* LOOKS FUCKEN SICK !
* no huge antenna wires sending high voltage through the engine bay
* no arcing out against body work
* no cross arcing
* never need coil wires ever again
* less plug fouling as more energy at plug
* less engine misfires due to loss of power at plug tip
Disadvantages
* need tool to take off plug modules (1 x allen bolt)
* initial cost (maybe double,triple,quadruple? a set of top shelf after market wires) LOL (still to work that out)
* may not fit all applications different cars, unique set ups)
* need to keep 2 x old wires off your IGN-1A kit to do base timing (take off module and plug up wires to fit inductive timing light pick up)
I am sure there is more in either side, but that mostly sums it up.
Yes I will test it, but no real need, went through development with my first COP set up, this one is much better in ever respect and suits the majority of users who run these coils
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-04-2015, 11:13 PM   #4
Cool, to me it looks like all advantages and pretty much no disadvantages lol. Removal tool? No biggie. Price? MIGHT be a problem but it has to be pretty ridiculous lol. Fitment? You're making it for an FD already, so that's a plus, and as long as it fits with my specific setup, no problem there. Keeping two old wires? I'm a hoarder of parts so I have no problem with that lol.
Oh that's cool, I don't understand most of the scientific stuff anyway lol. I tend to trust those that know what they're talking about unless something sounds really fishy. I just figured you'd do it anyway haha.
Old 01-05-2015, 10:34 PM   #5
RICE RACING
Don Mega
COP Adaptor is finished with insulation rubber plug and removable cover !
Refined cover plate
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-05-2015, 10:49 PM   #6
RICE RACING
Don Mega
Pretty much over this now
Shit is optimized as much as I can do it, without going mental in the process!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-05-2015, 11:02 PM   #7
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
That looks like a very nicely engineered piece Peter. Kudos.
Old 01-06-2015, 12:12 AM   #8
RICE RACING
Don Mega
Thanks man, smashed up a gay arsed video of it lol.....
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 07:12 AM   #9
RICE RACING
Don Mega
Fuel Injector O-Ring for coil end, fits like a finger in a bum. Totally sealed.
The spark plug end will have 2 O-rings using the factory ribs in counter bore, again tip top.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 09:19 AM   #10
RX SE7EN
RX SE7EN is on a distinguished road
Looks great. Why are you making the adapters instead of true coil on plug with just a shortened rubber boot over the coil and plug?
RX SE7EN is offline   Reply With Quote
Old 01-06-2015, 01:54 PM   #11
RICE RACING
Don Mega
These popular coils will not fit axially using that simple version of COP.
ALSO that way does not have a robust connection.
Rubber boots degrade over time, this system is designed for LIFE TIME performance, its the ultimate, never buy another lead, boot, cracked COP boot etc etc.
So design fitment and quality is reason its not the way I did it on my first system.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 05:30 PM   #12
RICE RACING
Don Mega
OK!
I did a major redesign config, this is the best I can package it for OEM use.
Tell me what you think? its under 14mm past the front edge of the rotor housing now!
*New engine bracket mount
*New coil spacer mounts
*Re-Oriented COP adaptors
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 09:09 PM   #13
Slides
Slides is on a distinguished road
might try to swap my cars over tonight and have a look at the shit hanging off the side of the block.
Slides is offline   Reply With Quote
Old 01-07-2015, 08:41 AM   #14
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Looks good Peter, I'm liking the redesign (I still run my PS)!
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-07-2015, 09:29 AM   #15
RICE RACING
Don Mega
Yeah its the best you can do with the IGN-1A POS, I wont waste any more time on them, I have investigated all mounting options and my V2 last one here is the best i will make for these.
The more compact version around M&W CDI coil will fit all standard cars in COP, sadly its an expensive ign solution.............. go figure!
p.s. I can supply just the COP adaptors and end users can deal with the headaches of custom brackets but be warned its not easy and poor mounting can cause issues!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
