crash auto?fix auto
I'm surprised to hear that you've gone away from NRS. My current engine is a series 5 stock standard, only minor casting flash removed from the intake ports. Rebuilt by myself all OEM mazda components. Great powerband, more then 2 years of abuse and road trips at 350+rwhp, 121+mph trap speeds in the 1/4, nearly 50,000kms of use......but I'm swapping in an REW that I will be using NRS seals with.
Have you changed due to some issue with the seals or to prove the durability of the OE components? From my findings the OEM items need not to be proven, but I'm moving to NRS to facilitate a longer overall lifespan of the engine at elevated power.....bad move?
Don Mega
The Ohlins are a beautiful street set up. Australia has fucked roads and they work well here.
#3 | |
Don Mega
FC3S
What spark plugs are you running rice, going to have to get some to suit the wi when I can finally afford the kit lol. You post my dli yet?
#5 | |
Don Mega
No I will post it Monday, thanks for the reminder!
FC3S
No you won't you'll post it Tuesday lol. Mondays public holiday. Are the trust ones worth running in a daily? They are pretty dear aren't they? I've always run b9egv as that's what dysons told me back in the day but they can go suck a cock
#7 | |
Don Mega
I daily drive the SP, cold starts gentle trips, pick the right heat range and they will never foul.... they last 50 times longer than EGV's too.
#8 | |
Don Mega
#9 |
Don Mega
Some more pics of my ride
![]() RICEFJ has joined the stable officially ![]() ![]() ![]() ![]()
#10 |
Can't.Make.Up.My.Mind.
for some reason i thought someone told me once that ceramic apex seals dont seal as well under low rpms. is this true?
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
#11 | |
Don Mega
Let's leave the non used parts hypothesis out of this one
#12 |
FC3S
I'm sold then. Now just gotta find a place to get them.
#13 |
You have quite the nice ride. I've really enjoyed reading through your experiences with your SP. I may have missed it, but what's your fuel setup like? Injectors, pump etc? Any thoughts on Injector types at all? When you say pump-gas, you're using the top grade available (91) ?
I really like those seats! |
#14 | |
Don Mega
![]() Fuel system is as follows Sard 280lt pump Sard Type RJ regulator (55psi static pressure setting) 4 x 1000cc Bosch injectors ATL foam filled tank Kenne Bell Boost-a-pump, full pump rewire Fuel used BP Ultimate or Shell V-Power < but not mandated, I have run it on lowest specification unleaded at high power setting. I tried many types of fuel injectors, Bosch 839's, Rochester's, Denso, but finally settled on the "pencil type" Bosch units of high impedance, they seem to work well. The seats are Don! I just came back from a 200+km drive for about 3 hours inc lunch stop, and the seats are unreal, very supportive
#15 |
Don Mega
Daily Driver
