Go Back   Rotary Car Club > All thing Racing! > Track JUNKY!
Track JUNKY! Road course oriented tech forum.. Talk about suspension set up, Track info, brake set up, etc..
Old 01-13-2010, 12:48 AM   #10
Brent
Sua Sponte
Brent's Avatar
I have the Raceshop bar too and I was planning on attaching the harnesses to it. Is that not a good idea?
Oh, I think I'm confused a bit. I only have the harness bar, not the roll bar. I don't think I would fit with a roll bar unfortunately haha. How tall are you Brent?
You will be fine to attach your harness to your harness bar.
I'm a little confused by your question You aren't loosing any headroom or any additional seat room with the M2/Raceshop roll bar as you can see in the pictures.
Originally Posted by Project10AE View Post
True... I just worry about the side impact protection that you have lost with a harness that does not allow you to be pushed away from the doors the way an OEM setup does unless you have side / door bar protection. If he was mostly wanting to do 1/4 mile stuff that would be one thing, but on the street and on a road course, side impact situations are much more likely.
I see completely where you are coming from. Spot on with the side impact accidents. I worry more about side impact accidents on track opposed to head on... but the movement or no movement in a side impact is a double edged sword I think. Side Impact causing side to side movement... bad(Fritz can tell you first hand). Side impact without movement and the object penetrates the drivers side compartment, such as a car running a red light on the street(which I don't know how much door bars would help)... bad. That also brings up head/neck restraints as well as side impact halo seats(for track purposes of course).
