#22 | ||
Rep Power: 10 ![]() |
Yeah she is, if I can keep traction. There's non in 1st or 2nd on low boost, and highboost breaks them loose in 3rd. I dunno if it's the cold roads or what but I can't keep the ass in line when I mat her. I gotta stop driving this car and get to work on her.
![]() Quote:
My solution is to change the mounting entirely on the rear inboard mounts so that the bolt drives through the rack downward. I'll make installation a TON easier as well regardless of the seat that I use. But that requires a steel box with a nut welded on the inside and welding it to the floorpan. Not something that everyone is up for as the prep would take wuite some time to clean off all the heat material, grind the primer down to bare steel, weldthrough prime everything, weld it, seal it etc etc. It's a cake walk with the car at my shop..... too bad all you guys live so damn far away from CT, well, alot of you.I could duplicate the mounts that I bulit for mine with the exception of the inboard rears fairly cheaply, but they would need to be welded to the RX8 tracks, or bolted. I prefer welding honestly. Maybe $125 for 6/8 mounts, or if I find that the rear inboard track can be cut and the factory bolt holes used we can figure something out.
-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- Last edited by TitaniumTT; 01-11-2010 at 04:19 PM. |
