Old 12-15-2009, 09:17 AM   #4
moremazda
shookmotorsports.com
moremazda is on a distinguished road
Originally Posted by Ed R View Post
I have removed my damaged engine from my car and have evaluated all of the parts I need to replace. My engine will also need to be rebuilt since there is rust damage inside the rotor housing due to coolant that leaked in. See attached pics. This is gonna get expensive! I have come to the conclusion that I should just buy another long block. I have located several JDM engines from different suppliers, but would love to hear some advice from the experienced members if this is the best way to go.
Ed from Peoria, IL
The route you take depends on what you want to use the car for and how reliable you need it to be. There is one source in particular (Japan2LA) that will get you a reliable salvage motor that could be used with reasonable confidence. He is not the cheapest source but he does not sell stuff that should not be sold.
On the other hand if you are looking to setup the car in the most reliable fashion than you need to build the motor from the ground up... yes it's pricey but you will at least know exactly what you have under the hood. Even with the best of salvage motors you will still have a salvage motor under the hood.
moremazda is offline   Reply With Quote
