#22 | |||
They both measure "mass air", or the amount of air flowing into the intake / engine. Quote:
IN GENERAL: A "pressure sensor" can only see pressure or positive pressure relative to "0 atmospheric (pressure). A "MAP sensor" (remember, "MAP" stands for "manifold absolute pressure") senses both pressure *and* vacuum. The "absolute" part means it ignores "relative to 0 atmospheric (pressure)". What this means is that MAP sensors start at "absolute vacuum" or very near that level - this is it's zero point. (Absolute vacuum is considered 30.0inHg or "-14.7psi" - most people don't like seeing "-" and "psi", but it's easier to explain this way.) At sea level or "0 atmospheric pressure", a MAP sensor will actually "see" ~14.7psi. http://wiki.xtronics.com/index.php/P...nversion_Table Now, in the FC's case, Mazda does call the non-turbo FC's pressure sensor a...well, "pressure sensor". The turbo FC's pressure sensor is called a "boost sensor". That just confuses the whole issue. :P This the learned, the non-turbo FC pressure sensor is actually a "1-bar MAP sensor" (reads vacuum up to "0" atmosphere); the turbo FC pressure is actually a "2-bar MAP sensor" (reads vacuum up to ~15psi of boost). Quote:
I hope the above clears things up. -Ted |
