Old 11-20-2009, 11:39 AM   #11
FC3S Murray
frustrated!
FC3S Murray's Avatar
Damn Sean, that blows. I thought one of the main advantages of the BB turbo's was the LACK of seepage? I might put a call into Garrett or a few turbo rebuilders and see what their input is on the whole thing.
Well thing is it is NOT a ball bearing. Apparently it is one of the very early 62-1 Turbonetics produced. To verify all I had to do was look up the turbo oil drain flange and if I spotted a hole in the casting with "shiney metal" behind it, it was a ball bearing. Mine just had the cast iron around the entire turbo shaft. So I wonder in regards to what you said Brian if seepage is normal on normal bearing turbos??
ANOTHER CHANGE: I was going to get my turbine housing ceraminc coated but I have done some research and it seems that ceramic coating only benefits race cars since they have well ventilated engine bays to scavange heat. Ceramic coating is good for heat insulation BUT doesn't reduce engine bay temps near as much as a blanket. I on the other hand want to reduce under hood temps and that is the soul purpose of the blanket.
This Ebay Blanket I purchased last year worked AWESOME only draw back is I have to install it after I put my DP on my turbo.The reason mine went tits up was because of the constant removal/install of my downpipe really takes a toll on that fabric once it has seen high temps. PLUS constantly pushing it out of the way to make my V-band secure to the back side of my turbo fucked up the fabric around the metal eyelets. I will need to install my new blanket once I have the DP mated to the turbo. If I ever need to remove my DP I will then have to cut the safety wire used to snug to blanket down and carefully remove..........WOW that was long winded haha
Add another 110.00 to my FC deposit. Worth it though.
Same pig, new soul
