Old 11-01-2009, 08:27 AM   #7
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Originally Posted by 12arotary View Post
On rx7club you can find a good running t2 block for less than 500-
just cause you have a sb just chilling doesn't mean its going to be cheaper it usually means you are going to be in the for sale adds in a month with a t2 rolling frame with mounted sb haha
if i got as far as to mount the small block i don't think i would sell it. that would be the hardest part of the swap. and i don't think i will have a problem getting a carbed sbc with a t5 tranny to work in the car. i have read many times that the t5 mounts very colse to stock, with the shifter coming up through the original shifter hole.
