Old 07-06-2009, 04:13 PM   #11
classicauto
crash auto?fix auto
classicauto's Avatar
Thanks Joe! So here's a question for you. The top mount dealy..... is that interchangeable? Meaning can I transfer my pump and sending unit and the top mounting piece to the S5 tank or do I need to source one of those as well?
The mounting pattern for the "cover" piece is the same, the main difference is the length of the assembly. But bolt pattern wise they're the same where they attach to the tank.
As for the straps, that would be a bummer if they were slightly longer. I guess I'll find out through the parts fiche though. Thanks a bunch Joe
Yeah like I said on the straps I'm not 100% sure....the last time I did that swap was a few years back on a resto for a customer and I don't recall which series straps I used. I bet though, that even if the S4 ones are shorter, you can probably tighten them down anyways given the length of the bolts.......but either way its nothing outside of your capability
