Old 11-21-2008, 03:01 PM   #16
BigTeddy
BigTeddy is on a distinguished road
Originally Posted by Jeff20B View Post
I'd only recommend a GSL-SE plate if you were EFI so the primary injectors have enough velocity to work heap big. Otherwise with a carb, use a Y plate. What you lack in low RPM veloctiy, you make up for with midrange power. Add porting and power goes up. You can't really port the SE plates much.
Jeff is right...the only advantage of using the gsl-se plate is for the use of fuel injectors...
Not much porting can be done to the gsl-se irons...
One Turbo At A Time
BigTeddy is offline   Reply With Quote
