Old 03-07-2008, 10:48 AM   #1
6p turbo LOW OIL PRESSURE!
This is updated from the other forum where originally posted...
motor:
- s5 6port turbo conversion
- s5 n/a block, stock s5 t2 everything else
- oil feed line taken from aftermarket oil pedestal
- tapped n/a cover for stock turbo oil return
- autometer sport comp elec. gauge in stock location
- mech oil pressure gauge in pedestal
problem:
Oil pressure upon initial startup of the motor was around 28-30 psi at idle and above 50psi at rpm. as motor warms up, oil pressure declines.
startup cold:
25 psi at 800rpm, 50 psi when I rev.
hot driving:
30-35 psi at 2k, 40-50psi from 3k on.
hot idling:
0-10 psi at 800, 15-20 psi at 1200.
Other:
- oil psi does not decrease (just stops around 50psi) at higher RPM
- 20w50 Castrol conventional
- Pure-one oil filter
- gauge wiring has clean, tight connection
mech gauge tested... pressure on the electric gauge accurate,
mech gauge shows 10psi at idle
oil is a grayish color, similar looking to antisieze (for threads) but darker and without being shiny... Is that a telltale sign of anything??
