Old 03-31-2015, 12:52 AM   #1
FC Zach
FC Zach's Avatar
Going back to EFI, question about fuel pump. .
So after having my car set-up for carburetion since 2005 I had decided it was time for something new and that I wanted to go back to fuel injection, I'll be running the engine via a Sprint RE/Ludwig harness so no OE harness is present (was pulled years ago). I have reversed a lot of things I had done to the car in the past like pulling out wiring I made for the ignition, fan, fuel pump and what not. .
I'm trying to keep things simple and want the fuel pump to run off the original wiring (i had it hard wired to an open spot in the fuse block). I have reversed the hard wiring and reattached the pump wire (the blue one with yellowish stripe) back to the harness by the fuse box.
My question is, will I need to do anything else to the harness under the dash (there isn't one in the engine bay) to supply power to the pump? I believe there is a relay by the steering column for the fuel pump, not positive though. Terrible pic but this is what I saw in my manual, I think it says "fuel injection circuit opening relay"
Also, is this something I will have to have?
If those things are necessary I may just hard wire the pump again, any suggestions?
Thanks in advance, Zach
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
