Old 07-27-2014, 07:49 AM   #1
Pete_89T2
Pete_89T2's Avatar
Warning Light Cluster problem
Yesterday all of the idiot lights in my warning light cluster with the exception of the brake & check engine light lit up and stayed on with the car running. The clock in the cluster still works fine, and I've done the cold-solder joint fix on the cluster years ago to correct the wonky clock. This is on an S5T2. Since I needed get somewhere, I just shut it off and switched to the daily driver.
I seem to recall this is "normal" idiot light behavior for FC's when you have an alternator/charging system failure - rather than just the "Charge" light coming on. Can anyone confirm this?
If true, then I should check out my charging system today. Assuming that checks out good, could this be another symptom of cold solder joints in the warning light cluster?
