Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Full Function Engineering
Full Function Engineering Full Function Engineering based out of Phoenix, AZ.
Old 03-20-2011, 02:41 PM   #1
fullfunctioneng
Triggers R Us
fullfunctioneng's Avatar
fullfunctioneng is on a distinguished road
GB: Full Function Engineering Crank Trigger Kits - S4, S5, and RE 13B's
It's finally here!
A well engineered, high quality, high resolution crank pickup for the S4, S5, and RE 13B Engines is now available to the public. (FD kits are nearly complete also) This kit allows those with high performance ECU's to run multi-tooth Motronic style wheels which offer greater resolution/sensitivity with zero rpm drift. The days of running a sloppy OEM CAS that has to be "stabbed" or an ultra low resolution two magnet Hall-effect setup are over. These kits are essentially bolt-on and go.
The 36 tooth wheel (renesis & 36-2) offers 3x greater resolution than a stock FC pickup (CAS) and 18x better than a two magnet Hall-Effect setup.
With competent tuning these features combine for the smoothest / safest / most stable rotary engine you've ever driven.
We currently have an ECU compatibility list that is expanding as we're able to test more ecu's, so stay tuned for your ECU to be next!
Details
6061-T6 Construction
Protective Anodizing
18-8 Stainless hardware
OEM Quality Crank Angle Sensor
Crank Angle Connector Kit
Original CAS O-Ringed Cover
Colors
Full Function Blue & Satin Black
Blood Red & Satin Black (coming soon)
Options
Renesis Wheel
2 Foot Shielded Wire Extension & Connectors
coming soon:
Hall Effect Sensor
60-2 Wheel
36-2 Wheel
Additional Information
For use with OEM crank pulley
Not compatible with Power Steering & Air Conditioning
Works on 1, 2, and 3 rotor engines
ECU Compatibility
Haltech
Platinum Sport 1000
Platinum Sport 2000 *(2 rotor only)
Sprint RE
Motec
M400
M600
M800
M84
M2R
M4*(No split timing)
AEM
30-1800
Electromotive
Tec 1
Tec 2
Tec 3/3R
Megasquirt
The retail on this kit is VERY reasonable @ $250 but we are offering an introductory group buy for Rotary Car Club members.
Group buy is as follows:
2-5 kits = $220 (~18% savings)
6-10 kits = $205 (~23% savings)
11+ kits = $190 (~29% savings)
*prices include shipping to the lower 48 states!* (Those out of country please ask for a shipping quote)
Payment forms accepted:
Paypal
Money Order
Cashiers Check
The group buy applies to other forums as well and all will be counted in the number of kits to bring pricing down for everyone.
If you have any technical questions/comments/concerns please direct to either:
FullFunctionEng@gmail.com or private messages.
Thanks!
The FD kits are nearly complete and will be posted soon.
fullfunctioneng is offline   Reply With Quote
ignition, trigger kit
