cxxxx|::::::::::::>
Rep Power: 17 ![]() |
Falcore
Well that's what i named him, yeah my car is a him. When i was going to buy the car most of my friends and family told me not to. So why not name it after a luck dragon. Anyways here's what it's gone through so far.
I bought it in April of 05 and my aim was for 400hp by 2011. It is now 2011 and i'm close (I think) but not quite there. When i first got him home ![]() I think i had it a full 2 days before i was already taking it apart Koyo rad install ![]() 5th gear sycro and full tranny rebuild. ![]() There's my problem ![]() Then i went to a Pettit ECU and underdrive Waterpump pully and Alt pully ![]() ![]() Battery relocation ![]() FMIC and AVC-R install ![]() Had to do some cutting to get the FMIC to fit ![]() Supra TT fuel pump ![]() HKS intakes and B&M short shifter ![]() Had to polish the intakes....cuz that's important right :bigrolleyes: ![]() ![]() B&M ![]() Dropped a few lbs with an HKS carbon TI exhaust ![]() ![]() Then i went with Whiteline/noltec rear diff bushings ![]() Old ones cracked and leaking crap ![]() ![]() Just before i started taking everything apart for Haltech platnum 1000, Escalade coils, AEM wideband, 99spec twins ![]() ![]() ![]() My buddy that was helping me with my haltech was also building a 1.5jz....lube that shaft ![]() So many wires ![]() Old on left new on right ![]() Fins on old turbo ![]() fins on new turbo ![]() Done ![]() Was getting some boost creep after midpipe install so i had to pull the turbos and port/grind out metal behind the WG flaper ![]() Before ![]() After ![]() I sprayed it pink so i could see how much i could take out and PINK MEENS DANGER! ![]() I forgot to take an after pic Last thing i did was a new gauge for Water temp, Oil temp, Oil pres ![]() Again with the wires ![]() Done. Remote is for Peak recal, color change, C to F, set alams and so forth ![]() ![]() ![]() Clean piston ![]() Steal braded brake lines ![]() I'm taking the calipers to be powder coated then everything will go back together. ![]() powder coater Calipers ![]() ![]() ![]() ![]() Fuel system is Rx7stores Ultimate fuel system. 850primarys and 1600secondarys Aeromotive FPR. ![]() Injetor Rehab blueprint ![]() ![]() Meth system, i'm hopping to start this on the 6th ![]()
