Old 12-15-2010, 08:57 AM   #15
Pete_89T2
Pete_89T2's Avatar
Circuit is not as simple as we thought...
Did a quick test of resistance on the terminals.
If the parallel circuit was as simple as above, measuring resistance across the towers should be nil - not the case.
In fact, the towers are isolated from the two coil inputs + and - (no surprise there), and there is no resistance between either tower to coil ground - kind of a surprise.
The coil outputs are isolated from every part of the coil body including from each other.
Twin, independent coil circuits wound within the coil body itself?
Ok, now it's starting to make sense. By inference of Ted's measurements, the tower outputs can't be wired in parallel. I can't draw & post the circuit, so hopefully this description will make sense to everyone if you reference NoDOHC's diagram and use your imagination.
If you added a 2nd distinct coil winding to the secondary side of the transformer, and connect one leg from each of these secondary windings to a common ground through a diode (i.e., allows DC to flow in only one direction, connect "-" side of the diode to ground, "+" side to coil winding) and the remaining coil leads become your L1 & L2 tower terminals, Ted's measurements make perfect sense. In effect, we have two secondary coils driven by a common primary coil.
