Old 05-23-2010, 08:22 PM   #16
Well the digital dash is already a certain. I need to verify the inputs first and what I can afford. Consequently from the stock sensor suite does the FC have Oil Temp?
No it doesn't. There are a bunch of options for mounting it though. I have the first produced RE-Speed adapter tower with the -10AN fitting on it for both pressure and temp. You could also just use a generic -10AN coupler with an 1/8" npt port. I would kinda prefer to know what the temp is as it exits the engine, rather than as it goes back in. I think that information would be more usefull even if it is scary as hell.
I don't have a Low coolant sender that works anymore (Ruined my low coolant sender when I attempted to mount it to my old radiator--may pick up a new one and try to find a nice round stock and actually get it drilled and tapped for the proper threads this time),
Stock one won't work. You'll need to get something that latches to grnd.
I'll also need to figure out if my low sump sender works anymore (some reason I don't think it does).
Same thing, need something that latches to gnd.
Fuel Pressure... I think I might hold off on that (as it would require purchase of a new sender).
Suck it up man, get the AutoMeter replacement senders. They're Delco or Dephi replacements for like $90. It's good info to have ESPECIALLY on a boosted engine. You know my history. With pressure vs MAP you can make a correction table that could keep you from chunking an engine.
Quick question: Can Digital Pulse Inputs (DPI) be used as a Digital Switch Input (DSI)?
On the MoTeC's - yes
Alright, another question for the general community: How does the Digital Dash hook up to the ECU? I'm assuming via the CAN bus system, but after going through both the dash manual and the ecu manual I don't see any instructions on installation to the ECU.
CAN bus is the way. Setup is specific to the combination. Which dash are you going with?
Here's the link to the spreadsheet I've done. It's still quite rough, but adjustments might be needed here and there.
http://spreadsheets.google.com/ccc?k...LMHIxcHc&hl=en
I'll check it out in a bit..... going to weld a fuel cell
