Old 11-11-2009, 11:51 PM   #22
NoDOHC
NoDOHC's Avatar
rotor housings are cheap.
I want to do a semi-pp, leave the primary ports alone (they close pretty early) and fill the secondary ports, then connect a throttle plate for the two primary runners (I was going to use part of a TII manifold). Each of the peri-ports gets an ITB that feeds the port directly. A progressive throttle linkage will allow the engine to only run on the primary ports until about 30% throttle, at which time the P-ports will start to open.
I think it will work very well. If you don't try it, I intend to. I have the utmost confidence that you can do the project justice.
