Old 07-17-2008, 04:21 PM   #16
mazdamaniac
mazdamaniac's Avatar
mazdamaniac is on a distinguished road
Could just be a blown hose on that housing.
There is a hose that goes from the top of the housing to the throttle body that often cracks.
mazdamaniac is offline   Reply With Quote
Old 07-17-2008, 07:15 PM   #17
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
I took another look at it and the leak is actually seeping thru the housing and the end plate on the passengers side. I first thought it was that hose you speak of but I replaced that one when I did the thermal bypass mod.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
