#76 | |
Cold Weber?
#77 |
Rep Power: 21 ![]() |
no its making the tach jumpy
#78 |
maybe the pick-up is failing in the dizzy they move a little and the wire may be broken inside.
____________________________________________ 1976 Cosmo needing lots of work 1993 Rx-7 410 RWHP single turbo toy 1985 Rx-7 toy/project car 411HP stoplight terror 2001 Dodge ram 4wd.parts hauler 2016 Ram 2500 cause its a hemi 2006 VW TDI commuter __________________________________________ I guarantee there's a pregnant redneck teenager somewhere in a shitty trailer park that thinks "Ebola would be a lovely name for their child"...
#79 |
Waffles - hmmm good
Take the tach signal from the msd if you can and see if it works fine.
Is it just the tach or do you feel it actually missing?
#80 |
Im going to try the tach off the MSD as well. I yea, I actually feel it missing. Stumbling quite badly when it occurs.
#81 |
i have some spare dizzys so ill be changing it out too if the problems persist past the coil and ignitor.
#82 |
#83 |
dizzy failed mechanically. was making loud clunking noises, replaced and she runs good minus the idle circuit. I need to get that dialed in.
#84 | |
Sweet.
#85 |
#86 |
#87 |
Rep Power: 13 ![]() |
Whoa... what is that about? I'm very curious
#88 |
breaks up and/or deflects the pressure waves (supposedly) and prevents them from bouncing back against the flat top metal lid.
#89 |
Found some larger 65 pump jets. Seems to have help some. Car still has off idle / light throttle leaning issues causing dead spots.
Racing beat muffler has replace the flowmaster so know it sounds better and quieter. A much needed thing. The motor that controls the vent mode for the heat went out so i just removed it so i can manually change the settings. I might fix it proper some day. I just was tired of no defroster. Also powersteering is back in the car with mazdatrix heim bumpsteer bits.
#90 |
