Old 11-25-2010, 07:00 PM   #16
sv51macross
sv51macross is on a distinguished road
The more I delve, the more I find out. So, in the hopes of gaining some access to the LIM bolts, I remove the airpump. I read the shop manual procedure, and go out. Now, I'm wondering why the heck can I not find the adjustment bracket. Then it hits me:
THERE IS NO adjustment bracket! So all this time, the support bolt/hinge has been keeping tension (or not) against the air pump belt.
NEVER buy a FC for $1000 off eBay.
So in all seriousness, before I loose my mind, anyone have nay tips for getting at the bottom two and rear two bolts on the LIM?
1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied.
Eventual plans? Something cyberpunk and spicy.
sv51macross is offline   Reply With Quote
Old 11-25-2010, 10:38 PM   #17
Mazdabater
FC3S
Handskills? Did you try the vacum cleaner idea of mine? I got a part of a zip tie out of mine by that.
Old 11-25-2010, 11:22 PM   #18
sv51macross
Don't have the right materials for a hose on hand. Plus, I've already invested so much effort into removing the LIM that I'm following through with it if it kills me. As an enthusiast, I must not be defeated by this, I must persevere!
Old 11-25-2010, 11:24 PM   #19
Pete_89T2
Pete_89T2's Avatar
+1... I suggested a shop vac many posts ago as well. I can vouch for the fact it works - saved my a$$ in a similar situation - dropped one of the fuel rail bolts in the LIM once and the shop vac sucked it right up.
Old 11-26-2010, 11:31 AM   #20
sv51macross
I got it out! I had to remove both 5/6 port actuators and then the LIM but I got it out!
Very lucky I was. The runner had 'chuted' the washer so it traveled at the port horizontally. The port necked down enough that the washer wedged horizontally in the port, so it never actually entered the block.
Whew!
So now I just have to reassemble the lower intake tract, finish replacing the oil injection lines, pressure test the fuel system, and reassemble the whole shebang.
Peace, and thanks for the support!
Old 11-29-2010, 10:18 AM   #21
Do it to it Lars! congrats on NOT doing something that we've all had that little adrenaline shot thinking about if it happened to us...
