Old 03-26-2008, 08:18 AM   #1
Deflooding RX8..
Someone please post some info about Deflooding Procedures??
This morning I couldn't start my 8 because its flooded
Old 03-26-2008, 08:24 AM   #2
Method #1
-Turn Key to ACC and Put The Gas to the GROUND and Crank for 10-15 Sec.
-Shut off
-Turn Key to start
Method #2
-Pull Fuel Fuse from the engine bay
-Wait a minute
-Crank the car without foot on the gas for 15 sec
-Turn off
-Put the fuse back
-start the car
Old 03-26-2008, 09:28 AM   #3
Old 03-26-2008, 09:30 AM   #4
Old 03-26-2008, 09:37 AM   #5
Old 03-26-2008, 07:23 PM   #6
Just got my car deflooded..
Now I understand about why some HATE 8's!! Yikes! It took me 2 hours to deflood..
I finally did it by replacing the sparks and doing the FUEL PUMP FUSE thing.. Its not the BIG BLUE Fuse that says, "FUEL". Its the Tiny 20A (yellow) FUEL PUMP Fuse..
After having my wife's MX5 jumped to the 8, I was finally got the 8 Started.. I would NEVER shut this FUCKING car down when its COLD! I even rev'd it up before shutting down and did this..
Old 03-26-2008, 07:58 PM   #7
fikren
fikren's Avatar
fikren is on a distinguished road
Did it flood on its own at operating temp or did you do a start/stop and even with the rev it was still "cold"?
93 bb rx7
Destined to be the never ending project car or possible part source for the rotary rat rod
2008 40th Anniversary Edition RX-8 - bankruptcy owned me
RE-Amemiya Super Dolphin Tail Exhaust-for sale
AutoExe Front and Rear Strut Bars-for sale
AutoExe Member Brace Set-for sale
2008 Honda CBR600RR - bankruptcy owned me
Motivation axle/fork/barend/frame sliders
ASV "unbreakable" shorty levers
Tripage Integrated Tailight and Adj FE
Proton Fushmounts
Akrapovic Hex Carbon/TI Slip On
Sato Rearsets
fikren is offline   Reply With Quote
Old 03-26-2008, 08:01 PM   #8
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
That's just a wives tale...if anything that's probably what caused the flood. The '04s did have a problem with "warm" flooding...it happened to me after a very spirited run on some back country roads once. But if I were you I'd take it in to the dealership and make sure all the flashes have been installed. There is a flash out there that helps against flooding. My car has yet to flood since I got that flash and I've tried to flood it! HAHA!
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
Old 03-26-2008, 09:08 PM   #9
I did the start stop.. ran the car for about 2 mins.. then I shut it off by 7K RPM and shut down.. Next day, didn't start (this morning).
Here are what the sparks look like..
I guess I'll head over to Trussville Mazda and see if they could flash my car before DGRR...
Old 03-26-2008, 09:11 PM   #10
Holy cow. Not as simple as the older rotaries is it.
I do like the nifty 'De-Carbon Kit'. Thats pretty convenient, if not about 30 years too late!!
Good info Phil!!
