Old 05-05-2009, 08:13 AM   #1
pedro a
pedro a's Avatar
pedro a is on a distinguished road
Question fuel help please
hi there im new here.im working on a 85 GSL-SE it's killing me. im getting NO fuel out of the regulater.i remove it and when i turn on the key im geting 70 psi from the fuel pump to the regulater.i replace the regulater with a new one and still no fuel coming out that with it of the fuel rail .i pull the one of my wife car that's runing and still no fuel can someone HELP me on this one.this is the first time i had to deal with this.i even replace the fuel filter and is that to much psi 70
pedro a is offline   Reply With Quote
Old 05-07-2009, 08:54 PM   #2
Are you sure you are going the proper direction with fuel?
I don't have much experience with GSL-SE's, but I assume they have a pulsation damper. The fuel should go from:
1) the pump
2) the filter
3) the pulsation damper
4) the rail and injectors
5) Pressure regulator
6) back to the fuel tank return
Make sure that is the correct order, and you are not going straight to the regulator.
Old 05-08-2009, 11:08 AM   #3
please post a pic of your problem if you can..
Old 05-08-2009, 03:28 PM   #4
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Check to see if the screw came out of the pulsation damper. Carefully take the plastic cover off, if the small screw came out of the diaphram plate it will be there. Have a pencil magnet or something like that when you take the cover off.
If it is out then replace it hand tighten. Do not replace cover Try it then. When it is running, tighten the screw again and replace cover.
And it does help the have fuel going in the correct direction.
