Old 01-14-2009, 04:41 AM   #16
Skatelement
Senior Member
Skatelement's Avatar
Skatelement is on a distinguished road
Gauges
Here is A link with some pinout info on the pannel connection if you need to pin A S5 pannel to fit the S4.
http://www.rotaryresurrection.com/2n...o_s5_swap.html
Rotaryresurrection page has alot of helpful info and tips listed. Spend some time and just read it all, It explains alot.
Skatelement is offline   Reply With Quote
Old 01-14-2009, 05:09 PM   #17
Not sure. I have a S5 NA cluster in my S4 NA, the only thing that didnt work right was the speedo, but that wasnt the cluster's issue... it was the speedo cable.
Old 01-14-2009, 07:50 PM   #18
firzen
Since there's activity in this thread again, I might as well provide an update:
Turns out there was something wrong with the one water temperature gauge- I tried all combinations of it with another gauge and the two dash clusters I had. In all cases it was the only weak link so I ended up not using that one.
The tachometer was also fine too. Turns out my throttle cable was a bit stuck too and made me think otherwise.
Fortunately, I'm not dealing with the S4/S5 gauge swaps.
