Old 09-07-2008, 06:21 PM   #1
afgmoto1978
afgmoto1978's Avatar
FS:Seals and Such
Here is what I have for sale:
Mostly complete Engine Seal Kit - Missing one outer water seal andoil drain crush seals. I decided to up rate everything else with Viton and originally used seals instead.
So I can either order all the missing parts for you and see the kit for $350 or piece part it. Shipping is extra.
Re-Amemiya Reflashed ECU - Seletable two stage boost - 12psi and 14 psi
This ecu will support the following mods - Intake, full exhaust, intercooler, street port, 99 efini twins. The AFRs are on the rich side for safety. Looking to get $450 shipped. This ecu comes with the a switch that looks like the center console fog light switch (for that hidden look).
20B Throttle body elbow - make reasonable offer.
Old 09-07-2008, 06:44 PM   #2
afgmoto1978
Viton water and oil control seals - 2700 miles put on seal, all are in good condition. $300 shipped (these seals aren't cheap, your looking at $550 worth of seals new)
4 brand new 850 side feed injectors - Nippon Denso units (don't let the SARD boxes throw you off) - $130 shipped or $475 shipped for all four.
Stock Fuel Filter - 2700 miles on unit - $15 + shipping
K&N Air Filters for Twin Turbos - $30 each shipped or $50 shipped for both
Old 09-07-2008, 06:53 PM   #3
afgmoto1978
Viton Seal Material - $10 per foot - 24 inches wide. E85 guys this is the stuff you need.
Intake or Brake Ducting - 3 inch Diameter - 25.5 inches long - $25.00 shipped
4" T-Bolt clamps with springs - the good stuff - $15.00 each shipped
3 omp injector resistors for 1600/1300 secondary injectors - New never used - $7 each shipped
Old 09-07-2008, 07:09 PM   #4
afgmoto1978
Aeroquip fuel lines:
3/4" - 54" - $25 shipped ($57 from vendor)
5/8" X 100" - $60 shipped ($110 from vendor)
3/8" X 25' - $300 shipped ($450 from vendor)
5/16" X 72" - $100 shipped ($210 from vendor)
Aeroquip and Frugola -10AN 90 Degree Reuseable fittings - $15 Each + shipping
Aeroquip Fittings:
180 Degree - $27
Tight 90 with 10An Male end - $25
Fuel Distribution Block - $100 ($150 new) shipped
Adaptor fittings - $8 each (1 -8AN and 1 -10AN) shipped
Frugola Straigth Reuseable - $12 shipped
Stock Pressure and Vacuum Chambers - $5 shipped
Check Valves - in good condition - $2 shipped
Old 09-07-2008, 07:22 PM   #5
afgmoto1978
Stock Electronic check valves
$10 each shipped
EGT exhaust temp sensor clamps - $5 each
EGT exhaust temp sensor screw in units - $2 each
Stock WG control valves - $10
Oil pedestal (ported for improved flow) - $2
20k mile stock Auto radiator - really clean item - $50 shipped
Greddy to Synapse BOV Adaptor - $15 shipped
Brand new Mocal inline oil temp/pressure sensor adaptor - -10AN male ends - $45 shipped ($58 from Pegasus Auto Racing Supplies)
Old 10-10-2008, 05:43 PM   #6
afgmoto1978
Sold - Brand new Mocal inline oil temp/pressure sensor adaptor - -10AN male ends - $45 shipped ($58 from Pegasus Auto Racing Supplies)
Old 10-16-2008, 11:48 AM   #7
Adam, Do you still have all the AN fittings?? I might need some of those.. also I'll take the turbo control solenoid
Old 10-16-2008, 12:59 PM   #8
classicauto
crash auto?fix auto
classicauto's Avatar
Not to be a PITA but the engien seal kit - "missing one outer water seal and oil drain crush washers"...........and that's it?
So it has oil control ring springs, seals, scrapers?
Side seal springs?
apex seal springs?
corner seal springs?
dowel land o-rings?
front and rear mains?
Doing a rebuild on another keg soon - very interested in some info, thanks
