Go Back   Rotary Car Club > REGIONAL FORUM > Southeast > Tennessee
Tennessee Mazda Rotary Car Club of Tennessee
Old 04-20-2016, 11:05 AM   #3346
Johnny_K
Johnny_K is on a distinguished road
Cool. I'll take them since I can't find mine.
Johnny_K is offline   Reply With Quote
Old 04-20-2016, 11:32 AM   #3347
project86
Can't.Make.Up.My.Mind.
project86's Avatar
any one happen to know this guy?
http://www.rx7club.com/2nd-generatio...rsary-1095691/
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 04-20-2016, 12:21 PM   #3348
almoststockfc
almoststockfc's Avatar
Them? Both?
-75 RE_W_PU -
Old 04-20-2016, 02:35 PM   #3349
excellent... and that was just with some timing changes. It you wanna get froggy you can run 35* and some negative split and really lean it out. But watch your EGT's.
EGT's are the reason I run 30-35* and .92L at cruise.
Currently at cruise he's around 30-32, -5 split, and have the o2 correction set to 14.4 target, which it hits pretty well. Unfortunately he doesn't have EGT so that may be as far as its worth going to be conservative. Still smells but isn't eye watering. Will be using logs to create some delta tables to smooth the correction over (sprintRE doesn't have anything built in AFAIK).
Didn't touch timing much up high, so there should still be power to be gained when he gets on the dyno. He is going to need some, as the Jismo beat him from 40-100mph on the way home
Old 04-20-2016, 02:49 PM   #3350
FC Zach
FC Zach's Avatar
Originally Posted by FerociousP View Post
. . . so there should still be power to be gained when he gets on the dyno. He is going to need some, as the Jismo beat him from 40-100mph on the way home
Hey now! ! ! Not by much, by any means lol
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 04-20-2016, 02:52 PM   #3351
Kewl Kewl.... the negative split helps in cruise... it lets you lean it out farther than stoich in the quest for mpg. I don't on my personal car though, even with EGT probes I like it around .92L
Time. At that point I think I would've pulled over on the side of the rd and torched it
I don't remember exactly what the timing was up high, it looked pretty good FWIR so you really need to just play around with it. Some cars like timing around 30, some much higher. The most I've made was darrells ITS car. non cheater motor and I did 196rwhp. That fucker wanted 35*+ and I ran it @ .905L or 13.3:1 AFR. Other cheater motors (ported) like to see closer to .85L or 12.5:1. They're all cranky and need their own level of attention
Old 04-20-2016, 03:37 PM   #3352
Just like you.
Old 04-20-2016, 03:40 PM   #3353
Says the guy who "blew a coolant seal" and would rather drink than drive FrankenB
Old 04-20-2016, 03:40 PM   #3354
FC Zach
FC Zach's Avatar
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 04-20-2016, 03:49 PM   #3355
#1 - I didn't blow a seal, it was already blown. Or as I call it 'breached'.
#2 - Drink away my sorrows. Or drink then drive
Old 04-20-2016, 03:59 PM   #3356
project86
project86's Avatar
Just like you.
Oh he's not that bad......
'90 GTUs
'10 Toyota Prius
Old 04-20-2016, 04:00 PM   #3357
1) I thought it was already shook down
2) Drink till the Dragon looks straight than get the keys
FUCKING PRIUS DRIVERS!!!!!!!!!!
Old 04-20-2016, 04:04 PM   #3358
1. If about 50 miles and 3 days counts as a shake down. Then I shook it like a shake weight. You saw the burnout? Were you not entertained?
2. 2017 goals.
Old 04-20-2016, 04:10 PM   #3359
project86
project86's Avatar
........ ....... I stand corrected.
I DROVE THE HIGHLANDER!
'90 GTUs
'10 Toyota Prius
Old 04-20-2016, 04:17 PM   #3360
FC Zach
FC Zach's Avatar
Same thing lol
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
boners, djs a poofter, extra boners, middle tn, super boner, who added boners?
