Old 03-21-2014, 02:37 PM   #16
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
PitstopUSA has the bearings. You'll have to do lots of measuring to get the right one and probably need a machine shop to make the receiver block for you. Knowing your love of fiddling with custom parts, it should be fun.
Old 03-23-2014, 05:45 PM   #17
well 8" toyota might be 8" mazda IRS....
Old 03-29-2014, 12:04 AM   #18
Busy day.
1. GSL-SE is officially gone. Cut the front corners for spares for the rally car.
2. Began the FD3S rx7 rear suspension. The gas cylinder is representative of how tall the towers will likely be since the strut mounts on top of the hub assembly. Various pictures of the FD rears and the spares (i acquired three dropouts in total. left one assembled for mocking up).
3. turns out the rear brakes are FUCKING HUGE since they ever-so-barely rub the inside of my enkei. Any rally wheels have a larger inner diameter?
4. Diff is nicely sized relative to the dewalt 18v batt used for reference. Good ring. Going with either 4.88 or 5.12. Currently has a torsen diff however, but i can get a clutch verison.
Old 03-29-2014, 11:48 PM   #19
engine bay is done! finally! You would be surprised how much detail shit went into it. And how variable a person can be while welding.... used much primer and various paints.
Old 04-08-2014, 09:07 PM   #20
progress from today.
Old 04-13-2014, 12:30 PM   #21
Old 04-13-2014, 12:55 PM   #22
chibikougan
chibikougan's Avatar
Cool!
Old 04-13-2014, 01:27 PM   #23
GySgtFrank
GySgtFrank's Avatar
It looks like it fit fairly well. OK, so relatively well, considering just how radical of a swap this is. Very nice.
Old 04-13-2014, 02:09 PM   #24
Old 12-21-2014, 04:52 PM   #25
Old 12-21-2014, 05:18 PM   #26
chibikougan
Moar!
Old 12-22-2014, 07:13 AM   #27
Dropped the fd rear in favor of something better. It fit but wasnt satisfied with a few things. Now for toyota 8" 4 link.
Old 06-06-2016, 08:54 PM   #28
wow I've updated this in forever....
Old 08-13-2016, 06:23 PM   #29
well here is how the rear brakes turned out. Ideally they should be...good. Or at least decent.
Slightly modified and rearranged disc brake mounts for the front calipers of a toyota pickup circa 1984. rotor hat modified to fit my axle I already had machined to a Saab rotor (thanks JVL!), and a 300mm non-vented rotor for said hat!
Old 08-14-2016, 12:59 PM   #30
chibikougan
Schweet!
