Old 03-12-2008, 12:11 AM   #1
sk8world
600rwhp club member.
sk8world is on a distinguished road
Spec clutch stage 3+ = unhappy!
Ok, I was running a ACT street/strip set up awhile back. Lots of drag racing with it. It finally went out on me about 1 year ago. I upgraded to the SPEC stage 3+ which is some metalic compound. Rated at 500+ft lbs torque. I broke it in with 1000 easy miles. (1000 miles because I was also breaking ina new motor that had to be taken back out for oring failure and then another 500 miles on the next motor). Then started running it harder and harder. While on the dyno it started to slip just a tad. I really did not know 100% forsure if it was. Later while doing some more high boost street tuning it started to slip in 3rd gear bad. I pulled it out tonight and it is burnt bad. Even wear but it was very harsh on my light flywheels. Wore pretty good into the disk, 4 times more than my act did with 30-35k miles. This Spec has maybe 3k on it.
sk8world is offline   Reply With Quote
Old 03-12-2008, 12:14 AM   #2
Dang man... Hate to hear that, but good to know.
Old 03-12-2008, 07:07 AM   #3
RXtacy
RXtacy's Avatar
How much torque are you making?
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-12-2008, 10:09 AM   #4
sk8world
400lbs.
Old 03-12-2008, 10:41 AM   #5
sk8world
So here is clutch, flywheel and presure plate...
Old 03-12-2008, 01:25 PM   #6
Mike, I thought stage 3s were 6 puck from Spec?
Old 03-12-2008, 01:48 PM   #7
spandy
spandy is on a distinguished road
The stage 3 is indeed a 6 puck....but this is a stage 3+ which is a disc.
But also on RX7 store, it says the stage 3 is rated at 520ft lbs torque, and the stage 3+ is rated at 598ft lbs torque....how the hell could it be toasted with only 400ft lbs torque when thats only like 2/3's of what it is rated at?!
spandy is offline   Reply With Quote
Old 03-12-2008, 02:24 PM   #8
sk8world
Bingo!!!! Thats my complaint. It is not doing what it should be doing. It is also very harsh on aluminum flywheels which they advertise as not.. If it was rated below what I was doing then there would be no complaint. I called and spoke with Jeremy @ SPEC before I bought this unit. I told him my goals and he assured me this one would hold. Now after all this I was told no replacement or credit as its been too long. Which it has since I lost my act clutch in the late fall. I did not even put the new one (spec 3+) in till spring only to find out I lost a motor when the clutch let go. SO back under the knife new motor in, has instant oring failure, months later back up, more break in, finally a tune and here I am know!!!. So all in all the clutch has been in the car for 3 years with less than 3k miles. = toast!
Old 03-12-2008, 01:50 PM   #9
sk8world
I think you are right Phil, but this is a 3+ Rated even higher. (rated at 598 lbs)
http://www.specclutch.com/csproducti...uct=stage3plus
Old 03-12-2008, 02:28 PM   #10
sk8world
http://www.specclutch.com/csproducti...uct=stage3plus[/QUOTE]
oops you beat me to it....
Old 03-12-2008, 10:31 PM   #11
I see!!! I didn't know there was stage three plus! LOL!
Old 03-13-2008, 02:55 PM   #12
spandy
Me neither...I looked it up.
Old 03-13-2008, 01:17 PM   #13
g's 3rd gen
g's 3rd gen is on a distinguished road
Sk8.. What light flywheel is that? I have the same one and need a new friction plate insert for it. I am now running a new ACT light fly and a Spec stage 3 (6 puck). It is quite harsh but grips well so far. I do not like the noises that my drivetrain makes now. Sounds evil on engagement. Oh well such is life. G
1993 FD3S base, SSM, 99 spec, A-spec t4 35r. 420 on pump gas
g's 3rd gen is offline   Reply With Quote
Old 03-13-2008, 07:51 PM   #14
sk8world
Mine is a Pettit. I know back in the day Sr racing offered one also. I bought a new disk from pETTIT for $80. They still show it on there site. I will have to get another also to complete mine for sale. The SPEC stage 3 is VERY harsh. I sent pics to SPEC and Mic the thickness on my disk last night. He said I had less than .02 wear on it. BUT it wore my flywheel 3-5 times more than my last act 40-50k mile disk.
I DO NOT RECCOMEND THIS SPEC STAGE 3+ TO ANYONE! IN FACT AFTER SEEING THEIR CUSTOMER SERVICE I WILL NEVER BUY ANYTHING SPEC!
Old 03-14-2008, 01:42 PM   #15
cewrx7r1
The Judge
I read from another site that this clutch is not suitable for street.
It is for race and has to be HEATED up first before it will stick.
