Old 06-05-2009, 05:33 PM   #1
low compression
low compression is on a distinguished road
boost creep
I put a racing beat exhaust on my 88 t2 with the na mufflers i had laying around. At the same time i swapped to a stock turbo i had laying around since the other one smoked a little. I ported the wastegate almost to the flapper and boost wants to get to 12 psi if i go any more than part throttle. All i have not stock on the car is a fcd all stock intake. does this seem to be a bit extreem for a exhaust they sell as a direct replacement. Is my actuator bad. it sucks babying around in my car i cant even pull out in traffic without possibly hitting 10+ psi. Is this normal with the exhaust or do the na mufflers flow more than the turbo ones causing this. Any input would be great
low compression is offline   Reply With Quote
Old 06-05-2009, 05:38 PM   #2
RotaryProphet
The exhaust by itself will cause the system to run 4-5 psi above stock (how bad must the mazda system have been, seriously?), making a FCD almost necessary.
Old 06-07-2009, 09:25 PM   #3
low compression
with the fcd how high is safe with stock everything else. should i just keep driving quarter throttle. im in the process of building another engine for it to install this winter but dont wanna detonate a 95 psi compresssion engine regardless
Old 06-07-2009, 11:20 PM   #4
That's normal after an exhaust upgrade. The porting should help keep you from creeping but I am wondering about the wastegate too. It should be opening up around 5psi-6psi. The FCD is doing it's job but 10psi is the most you want to reach with a bone stock car. You need at least a fuel controller to safely hit 12psi.
Old 06-07-2009, 11:35 PM   #5
low compression
i think i have a actuator at my moms ill switch next time i go down. i know my wastegate port wasnt extreem but i figured it would be sufficient for a exhaust upgrade made for a stock vehicle
Old 06-08-2009, 12:15 AM   #6
well, the stock one is internal actuator....I assume yours is aftermarket?
Old 06-08-2009, 11:29 AM   #7
low compression
maybe my terminology is incorrect but i was referring to swappin the big actuator like thing that has the rod that connects to the wastegate to open it. Its bolted to the side of the cold side housing and has the line that runs to the outlet of the cold side
Old 07-05-2009, 01:30 PM   #8
rotarybeat1287
Member
rotarybeat1287's Avatar
rotarybeat1287 is on a distinguished road
Don't use an FCD... its tricking the computer by making it think its running lower boost. I recommend an Rtek. It, instead of not having fuel like an FCD, adds fuel above stock levels and retards timing a degree per PSI above 9psi. It also smooths out the staging points. Pretty inexpensive and a safer route for a simple TII w/ a turbo-back exhaust, and ported waste-gate.
rotarybeat1287 is offline   Reply With Quote
Old 07-08-2009, 05:42 PM   #9
TehMonkay
Put in a haltech.
Old 07-08-2009, 06:30 PM   #10
$40 FCD + $200 A/F controller
vs
$400 Rtek
vs
$1100 Haltech ECU.
If you're going to rock the stock setup then just stick with FCD and AFC + tune or the Rtek...no point in blowing $1100 on a setup you don't need.
As far as the wastegate, if it's jammed or not opening properly then you should replace the components. Any new info on this issue?
Old 07-08-2009, 09:27 PM   #11
Flooder
Flooder's Avatar
Flooder is on a distinguished road
Ive got a full 3" turbo back on my car and I don't have any boost creep. I don't know if my wastegate has been ported or not, but I would assume with a rebuilt motor and the exhaust I would be creeping a lot. Kinda weird I guess.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 07-09-2009, 03:13 AM   #12
Boostmaniac
You left one possibility out.
A screwed up turbo.
That's what I was rocking for a while, check it out if you can.
Full 3 inch turbo back exhaust = boost creep. Anything less means something is either wrong or you have been misinformed.
Old 07-09-2009, 03:11 AM   #13
Boostmaniac
I agree with Phoenix to a degree.
Rtek imho is the best route to go for higher stock levels but not wanting to get crazy.... yet.
FCD and AF controller doesn't make up for what you can do with an Rtek which requires no wire splicing. Yes it is more expensive, but you get what you pay for.
Old 07-09-2009, 07:12 PM   #14
Flooder
Flooder's Avatar
I have a freshly rebuilt s5 turbo, it has just as many miles as my motor, which is less than 4k right now.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 07-09-2009, 07:54 PM   #15
maybe it's ported....unported with 3" exhaust spiked to 15 psi on me....scared teh crap out of me.
