Old 04-24-2009, 07:25 PM   #1
Rotary#10
Rotorhead
Rotary#10's Avatar
How to ground you N/A FC ver. 1
Hey folks I am thinking of making a sticky Faq here for everyone who has added grounds and or cleaned them.. let me know what you know about grounds... I will be collecting info from other sites and posting the write-ups, and links to the orginal link.
So post away what you know about ground and the benefits you have..
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 04-25-2009, 04:36 PM   #2
My5ABaby
My5ABaby's Avatar
I'm a believer of just cleaning the factory grounds. The ones on my car have worked for the past 23 years so I kind of doubt I would need to add more. The only time I suggest adding a ground is for the 3800 rpm hesitation. However, that only applies to '86 and, I think, up to '87.5 cars.
Community Service Manual
RotorWiki
Old 04-25-2009, 05:08 PM   #3
SecondGenPat
Start a Revolution
SecondGenPat's Avatar
SecondGenPat is on a distinguished road
I ran 2 wires from B- to the tab on the firewall that runs to the top of the engine for the pcm ground. I still have the slight 3800 hesitation that I've always had.
That to secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, — That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
-The United Stated Declaration of Independence
SecondGenPat is offline   Reply With Quote
Old 04-25-2009, 09:17 PM   #4
My5ABaby
My5ABaby's Avatar
The 3800 hesitation is due to a specific ground, namely the one coming off the pressure sensor (in the engine bay). You can either reground right next to the ECU, or do what I did and splice in a new ground to that wire in the engine bay.
RotorWiki
Old 04-25-2009, 06:10 PM   #5
Cp1
Cp1's Avatar
there is a tech article i wrote in general info that has all to do with grounds. i quick smear of di-electric grease on ground points will ensure they dont corrode
Old 04-30-2009, 12:19 PM   #6
Fidelity101
Reliable Source
Fidelity101's Avatar
I just wire wheeled all the factory grounds and ran a semi thick gauge wire between all of them that loops from engine group to ECU ground. no hesitation here!
I also did re ground the map sensor too.
My Rx-7 Vids
Old 04-30-2009, 03:55 PM   #7
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Which wire on the pressure sensor is the ground? Is it the black one with the white stripe? Im assuming it is being as black is usually ground but i dont want to go ground the wrong wire lol.
EDIT: Found a diagram, no more hesitaion YAY!!
Old 04-30-2009, 06:36 PM   #8
I would like to chime in: I cleaned my grounds, however the wire inside the insulation and the insualtion itself were in such terrible shape, I had to unwrap the engine wiring harness, cut out a large section of the ground wire (including both on-engine ground terminals) and solder in new wire and B-Crimp (OEM style crimping method) ground terminals. This is an exteme case however.
Old 04-30-2009, 06:41 PM   #9
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Im kind of scared about what my harness really looks like, last time i had to peel back the tape on the main harness from the computer it was full of old coolant (shudder......)
Old 04-30-2009, 07:19 PM   #10
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Kind of a stupid question (I'm an electrical noob lol), but for the pressure sensor reground, do you basically just cut the wire, and solder the ends back together with a 3rd wire added to the joint, and ground that 3rd wire?
Like this?
Old 05-01-2009, 09:43 AM   #11
My5ABaby
My5ABaby's Avatar
Like this?
Yeah. I would also suggest cleaning the factory ground point as well.
RotorWiki
Old 05-04-2009, 06:26 PM   #12
takahaski.r
rotard
takahaski.r's Avatar
takahaski.r is on a distinguished road
i did the hks circle earth system, gold plate to negative battery with 6 wires coming off to engine, one to each of the housings and one to each of the irons
and one to the main harness ground. i have no hesitation at any point, and no more bogging from starts. this is in my 90 GTUs
pissed off?being that close to a rotary, id say youd be pist-on
takahaski.r is offline   Reply With Quote
Old 05-06-2009, 07:00 AM   #13
Nicely done.
I think that HKS thing is a waste of hard earned money. You could've done the entire thing yourself for much cheaper. Also, grounding the int and front iron are kind of a waste. The rear holds the coolant sensor for the gauge, so that is kinda nice to re-ground.
The housings are key for good spark so I would definately ground those, as well the ECU points, housings, waterpump housing, TPS, pressure sensor, and maybe the MAF. Everything should be common and leading to a GOOD chassis ground or to the battery. When I did mine I started with an 8 gauge grounded by the ECU that spiderwebbed out with CRIMPS (NOT solder) to hit all the key points.
