Old 04-14-2009, 08:04 AM   #1
NOLA RX-7
NOLA RX-7 is on a distinguished road
Now What ???
Ok Waste gate is port .no emissions , gas pump new ,OMP new, TPS new, sparks plug and cables new, front mount new intake new, blow off valve new, boost sensor new, ECU new. Pressure of gas pump is good Timing is by the book .
And the car still miss fire any more ideas so i can buying more stuff.
NOLA RX-7 is offline   Reply With Quote
Old 04-14-2009, 10:38 AM   #2
Test parts instead of buying them to ensure that they are working before replacement.
Honestly, it may be carbon build up and incorrect oil so it's causing pre-ignition events. When's the last time you had your injectors cleaned?
Old 04-14-2009, 03:49 PM   #3
NOLA RX-7
Well I bought the engine last month at tigerjaponise. So never. you think injectors . What or were is the carbon build.
Old 04-14-2009, 05:27 PM   #4
Compression is good?
Vac leaks?
Put up a video
Old 04-15-2009, 12:09 PM   #5
NOLA RX-7
Vac leaks?
Put up a video
You think carbon build can caused? OR Intake thermo sensor ?
Old 04-15-2009, 12:16 PM   #6
You haven't told us enough to say for sure. Get your stuff checked so we know what's going on with the engine so we can actually know the deal with it.
Old 04-15-2009, 12:46 PM   #7
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Would this perhaps be tiger direct, cause i have never heard of a single person getting a good engine from them
Old 04-15-2009, 12:50 PM   #8
Maybe, can't say for certain until we get some numbers. Compression numbers, sensors spec'd etc. If your compression numbers are low it may be carbon hold back some seals, but then again it may be time for a rebuild. If the injectors are clogged getting them cleaned and flow tested may actually be the best option. The problem comes from not being able to know if the AFR's are running rich or lean. Also, what are the conditions of the Spark Plugs?
Old 04-16-2009, 11:16 AM   #9
oh, ok, i thought it was new lingo I wasn't up to date with check your spark tho.
Old 04-16-2009, 11:37 AM   #10
NOLA RX-7
From no were stop misfire. Good Now the engine don’t have power if I floored . I check engine light and turns off on and stays on with this site.
http://www.johnr.com/cpucodes.html
Old 04-16-2009, 12:22 PM   #11
you're not writing too well so I can't fully understand what you're trying to say....I think you said the misfire stopped but now you have no power when you floor it and the check engine light is on. Right?
http://rotarycarclub.com/rotary_foru...51&postcount=7
Check those ^^^^ links and start testing the TPS...
those directions are fairly simple to follow but the most important is making sure there are no dead spots throughout the whole range.
Old 04-16-2009, 04:13 PM   #12
NOLA RX-7
yeah thats right
Old 04-16-2009, 05:35 PM   #13
keep us posted.
Old 04-16-2009, 06:07 PM   #14
NOLA RX-7
keep us posted.
any ideas??????????? I did the engine code What is this, 1 long light.
Old 04-16-2009, 06:20 PM   #15
retest TPS, check AFM, check leading spark (coil, main relay, plugs, wires), recheck for vac leaks...pretty much everything everyone has recommended.
I gave you links to info on HOW to make your own code tester to pull the codes and further pinpoint the issue....the links also includes a short list of codes, and how to tune your TPS. That same thread has a link to the FSM which explains how to test the AFM, the coils (although I've never wanted to test the coils like the FSM says due to fear of getting electrecuted)....
The best tip is start with a compression check THEN test the TPS.
